Insulating joint (cable lugs)
ceasar20
14
dear all,
in order to connect surge Surge Diverter , its possible to add and weld cable lugs on pipeline insulating joint (thickness 8.6 mm) ?
thanks in advance
Is it possible?
Yes, but only on the spool element and not on the section containing the insulation material
These are usually standard attachments.
You could also braze it on to reduce temperature issues.
Yes SJones ,full length internally coated
@dorri,
Thus, will there not be an impact on coating integrity from the welding activities?
Steve Jones
Corrosion Management Consultant
All answers are personal opinions only and are in no way connected with any employer.
Draw us a picture of the IJ and where you want to weld on your missing lugs.
why were these not included on the original data sheet / design? They are pretty standard items.
You can also weld them / CAD weld them on outside of the IJ and its spool piece.
