Oct 26, 2018 #1 ceasar20 Mechanical Joined Mar 2, 2014 Messages 14 Location CI dear all, in order to connect surge Surge Diverter , its possible to add and weld cable lugs on pipeline insulating joint (thickness 8.6 mm) ? thanks in advance
Oct 26, 2018 #2 LittleInch Petroleum Joined Mar 27, 2013 Messages 23,030 Location GB Is it possible? Yes, but only on the spool element and not on the section containing the insulation material These are usually standard attachments. You could also braze it on to reduce temperature issues. Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Oct 26, 2018 Thread starter #3 ceasar20 Mechanical Joined Mar 2, 2014 Messages 14 Location CI thanks LittleInch Upvote 0 Downvote
Oct 26, 2018 #4 SJones Petroleum Joined Apr 22, 2001 Messages 3,946 Location GB Has the full length of the item been internally coated? Steve Jones Corrosion Management Consultant http://www.linkedin.com/pub/8/83b/b04 All answers are personal opinions only and are in no way connected with any employer. Upvote 0 Downvote
Oct 26, 2018 Thread starter #5 ceasar20 Mechanical Joined Mar 2, 2014 Messages 14 Location CI Yes SJones ,full length internally coated Upvote 0 Downvote
Oct 27, 2018 #6 SJones Petroleum Joined Apr 22, 2001 Messages 3,946 Location GB @dorri, Thus, will there not be an impact on coating integrity from the welding activities? Steve Jones Corrosion Management Consultant http://www.linkedin.com/pub/8/83b/b04 All answers are personal opinions only and are in no way connected with any employer. Upvote 0 Downvote
Oct 27, 2018 #7 LittleInch Petroleum Joined Mar 27, 2013 Messages 23,030 Location GB Draw us a picture of the IJ and where you want to weld on your missing lugs. why were these not included on the original data sheet / design? They are pretty standard items. You can also weld them / CAD weld them on outside of the IJ and its spool piece. Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Oct 27, 2018 Thread starter #8 ceasar20 Mechanical Joined Mar 2, 2014 Messages 14 Location CI already included in our data sheet . BR https://files.engineering.com/getfile.aspx?folder=1150b8c8-82cf-4039-ac21-3ceafaffa5e7&file=ij.pdf Upvote 0 Downvote
