Instruments & Energy Efficiency
Zineb2008
Industrial
Jul 19, 2013
4
Hi all,
Are there any specifications to be taken into consideration, when choosing instruments, to improve energy efficiency?
Thanks.
huh? could you be a trifle bit more specific? what types of instruments? for what application?
TTFN
faq731-376
7ofakss
The one I can think of is instrument air consumption.
Most valve positioners bleed instrument air on a continuous basis. A plant with a couple hundred modulating valves uses a lot of instrument air just holding the current position. The Siemens PS2 positioner consumes no air when it is idle or holding its position, it consumes air only when it is changing position.
The 0.5 watt of electrical power that a loop powered transmitter consumes (at 20mA) is inconsequential in the bigger scheme of things.
