Instrument manifold
centaur21
44
I am trying to locate a manufacturer of an ANSI 10,000# 5 valve instrument manifold. I've been to Anderson Greenwood and the best they offer is a 6000# rating at 200 deg. F.
I would appreciate any leads you can give me on looking a manifacturer that fits the 10,000# rating. Thanks!!
As no ANSI 10,000 rating exists, please clarify if you need manifolds rated 10,000 psig at 100 degree F or some other criteria.
Many manifold manufacturers exist besides Tyco a.k.a. Anderson Greenwood.
Bilok
Hexvalve
Parker
Oliver
Swagelok
API has a 10,000 psi standard, look under oil field equipment API. Cameron, Parker
I have finally found someone. I called PGI International which gave me info on a manifold that rates 10,000 psi at 200F and the distributor is Rawson & Co. Thanks for the help guys.
