MikeHalloran
- Aug 29, 2003
- 14,450
SW2009.4.1
Created an extruded solid (of a radial wire in a fan guard) and an axis.
Made a circular array of the solid around the axis.
Went back to pick "Instances to Skip"
The help file says the pointer changes to a hand when you hover over an instance.
IT DOESN'T.
For the longest time, I was zoomed in too close to the axis to notice that what really happens is that a pink dot appears at the centroid of the body.
Hover over that and the instance number appears nearby.
Click the pink dot and the instance number appears in the skip select box, and the instance disappears.
Just one small example of how the help pages are out of phase with the product.
If it was free or cheap, I wouldn't complain about that.
Since SW is very much not free, I expect more.
Mike Halloran
Pembroke Pines, FL, USA
IT DOESN'T.
Mike Halloran
