My facility has a condenser and a reflux drum off the top of a distillation tower. The reflux drum has two outlets.
1. A vapor sent forward to a waste line and
2. A liquid that is returned to the tower as reflux.
The product that we condense in this exchanger condenses at temperatures above ambient. We get complaints if we send any liquid into the vapor waste line.
We are having issues right now because the condenser and reflux drum do not have an equalization line. We will sometimes pull a greater vacuum in the condenser than in the reflux drum. The reflux drum then begins to back up and eventually liquid covers the vent nozzles and we end up getting liquid in the waste line.
One proposed solution is to add an equalization line between the two pieces of equipment but are concerned that if any vapor product that bypasses the condenser it will enter the waste line as a vapor and then eventually condense due to heat loss in the line.
Is there any way to pressure equalize a condenser and a reflux drum without having hot product bypass?
Appreciate the help.
