INSTALLING 2007 FROM CD OR DVD??
toycept
Does it make a difference, or... are there any benefits installing 2007 from the CD over the DVD or visa versa... other than the DVD installation providing the 64 bit version?
thanks.
Not aware of any differences except not having to switch disks a couple of times.
SW06 SP5.0
Flores
No "insert disk X" dialog boxes when using the DVD. I'm sure that would make it a touch faster and you don't have to "baby sit" it waiting for it to finish each CD.
Not sure that helped just my two cents.
Grant
Applications Engineer
SW2006 SP 4.0
IBM InteliStation Pro M
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 3000
Installing from the DVD just keeps things simpler by not having to switch discs.
[cheers]
Helpful SW websites faq559-520​
How to find answers ... faq559-1091​
SW2006-SP5 Basic ... No PDM​
thanks all for the replies.... DVD it is.
I've heard it's frustrating trying to install the 64 bit version from the CDs...
:-P
To add to this, when running service packs you need the original media, so unless you are going for a DJ career I too suggest using the DVD...
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
If you have an admin image, you don't need the original media.
Admin images rule!
Don't get too confortable with CD's or DVD's, in a few years they will be gone.[wink]
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
I agree ctopher.
Cd's in particular are close to being obsolete with internet connections getting faster/being able to send large files.
DVD's will be around a few more years till you can dl that large of a file efficiently.
Opps this is way off topic. O-well it's friday and I'm bored.
Grant
SW2006 SP 4.0
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
I make an admin share on my computer and patch it, or rather i did till i got the dvd, i still may, i patch my boss's computer also.
depends on how many computers you have to patch in the long run in my opinion....
I am in a small company with little IT support, i am the solidworks guru and i am the lead prototype machinist
No, the DVD contains both the 32-bit and 64-bit versions of SW2007.
Sorry, I misunderstood what you were trying to say. You are correct; only the DVD has the 64-bit version, not the CD's.
