rockman7892
I work on a lot of design build projects where our engineering team creates a set of design/construction drawings which will include equipment (switchgear etc..) that is provided by other vendors and will have their own show drawings specific to that equipment.
On many projects there are cases where we need to reference these vendor drawings for external integration (external wiring interconnects) etc. usually there is debate on how to best incorporate these vendor drawings into our design construction package.
There are some that are of the thought that you can simply take that content of that vendor drawing and remove the vendors border and any other origin reference and simply put the drawing content in one of our project design drawing title block. There are others that believe that we should always keep the manufacturer drawing references for document control and recommended just putting our project design drawing title block around the existing vendor drawing title block. If there is a case where the original manufacturer title block is not kept there should be a note on the new design drawing that specifically references the original manufacturer title block.
I am of the though that we should always keep the original manufacturer drawing reference and should not just completely wipe out any reference to the original manufacturer drawing.
I'm curious to hear feedback on best practice that others follow?
A simple example here is taking an internal wiring diagram from a switchgear manufacturer's drawings and incorporating it into our design drawing set to show external wiring that will integrate into this internal switchgear wiring.
