Is it possible so insert/update more than one block at a time?
As you can probably guess, I have several diagrams that share the same 10-15 blocks. The blocks are stored as separate files (should have just used xrefs?). I decided to make some changes to the block files, and I would like to update them in my diagrams without having to Insert Block ->> Update ->> Repeat for 15 blocks, then do the whole thing over again for the rest of the diagrams. Is this possible?
Thanks for your help.
Dave
Dave
