Insert Text from file
Martynw
GB
Hi
Recently discovered that in NX9.03 running through Teamcenter, the Insert text from file function in the Note command does not work. We add in standard Material and Finishing process notes to all of our drawings, so this is a key function for us, as I imagine it is for a lot of other users.
Despite this being logged with Siemens, it will not be fixed until NX10. Are we really expected to run for a whole version without this function?!
I would put in for a backport to NX9 with Gtac.
Please give the IR for this we will probably also hook on...
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Created a new IR for the same issue.
According to Gtac this is only happening when running NXManager mode. and only after NX9.0.1
Response is that it will be fixed in NX10. Of course we didn't agree on that and requested a backport to NX9.
After that I received following from Gtac.
Gtac said:
I've tested and found this issue solved in NX 9.0.3.4 MP2. Will become available around 6 nov 2014.
Mechanical Engineer
NX8.5.3 / TC9.1.2
