Insert dimensions into a drawing
Pachem
LV
Is it possible to make button "mark dimension to be imported into a drawing" off as default?
No there is no option anywhere to Turn off this function. Only and RMB uncheck "Mark for Drawings". You might be able to create a Macro that would turn this off for every dimension after the model is completed.
Scott Baugh, CSWP [pc2]
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
