John,
I believe that what he is asking for is an "auto-text" feature. I don't recall the name and I'll have to dig the information out.
This is something that we've had in our drawing patterns and a grip script would be used to popuplate it. We also have a grip script that's used the add a revision to the drawing which would also update this date.
Mind you we're also still using NX1.
To get around this there's text entries that you can put in your templates that look something like
<W$=@DATE>
I can't seem to find my list of what's available at this time however I know that there are ones that you can use that will take the file name and populate it in as the drawing number, the current sheet number, the total number of sheets, and date.
I don't know if this is just an NX5 thing or when it appeared. We're trying to use this in combination with templates to get away from patterns and grip as much as possible.
The only problem that I forsee with this is that when he goes to print the drawing whether or not the date will update. i.e. sinico creates a drawing on 1/1/2006. He opens it up today to print it, will the auto-text update it to todays date prior to plotting?
Thanks,
Brian
