well that depends. typically it is done after weld bead working but before sizing. Since sizing is less than 0.5% it doesn't impart much work. By the same token it does have to be after the weld bead cold working since this should; be about 5% cold reduction of the weld bead.
The other comment of to decide if this is actually an anneal. I have seen much stainless tubing recently that was not solution annealed (non-uniform grain size and odd distribution of carbides) coming off of inline systems. It meets the mechanical properties so they call it good. It wouldn't pass corrosion tests.
And don't be fooled by the phrase "inline bright anneal", the inside surface is not bright annealed. The ID only sees an inert gas so there is measurable (even if invisible) oxidation on the ID that greatly reduces the corrosion resistance. This is 'wing and a prayer' tubing.
Plymouth Tube
