Ink Composition in Ink Jet Printers 1
AlanJ
Chemical
Does anyone know the basic chemical composition of the ink used in ink jet printers?
There are many different types - but here is Xerox's dry ink cartridge. Other MSDS's for a particular brand may be obtained directly from the manufacturer.
OHIO STATE UNIVERSITY COLLEGE OF BIOLOGICAL SCIENCES MSDS FILE
XEROX -- TONER-DEVELOPER CARTRIDGE-DRY INK CARTRIDGE
MATERIAL SAFETY DATA SHEET
FSC: 6850
NIIN: 00D002802
Manufacturer's CAGE: 26921
Part No. Indicator: A
Part Number/Trade Name: TONER/DEVELOPER CARTRIDGE/DRY INK CARTRIDGE
General Information
Company's Name: XEROX CORP
Company's Street: XEROX SQ, 100 CLINTON AVE S
Company's City: ROCHESTER
Company's State: NY
Company's Country: US
Company's Zip Code: 14644-1877
Company's Emerg Ph #: 716-422-2177 (XEROX CORP, NY)
Company's Info Ph #: 800-828-6571
Record No. For Safety Entry: 001
Tot Safety Entries This Stk#: 001
Status: SE
Date MSDS Prepared: 18DEC91
Safety Data Review Date: 18MAY92
MSDS Serial Number: BMTTN
Hazard Characteristic Code: N1
Ingredients/Identity Information
Proprietary: NO
Ingredient: IRON OXIDE
Ingredient Sequence Number: 01
Percent: 45-55%
NIOSH (RTECS) Number: 1004029IO
CAS Number: 1317-61-9
OSHA PEL: NOT ESTABLISHED
ACGIH TLV: NOT ESTABLISHED
Other Recommended Limit: NONE SPECIFIED
Proprietary: NO
Ingredient: STYRENE-ACRYLIC COPOLYMER
Ingredient Sequence Number: 02
Percent: 40-45%
NIOSH (RTECS) Number: 1003585SA
CAS Number: 25767-47-9
Proprietary: NO
Ingredient: POLYOLEFIN
Ingredient Sequence Number: 03
Percent: <5%
NIOSH (RTECS) Number: 1003224PO
CAS Number: 9003-07-0
OSHA PEL: 5 MG/M3 AS OIL MIST
ACGIH TLV: 5 MG/M3 AS OIL MIST
Proprietary: NO
Ingredient: SILICA GEL
Ingredient Sequence Number: 04
Percent: <2%
NIOSH (RTECS) Number: VV7310000
CAS Number: 112945-52-5
OSHA PEL: 6 MG/M3 TDUST
ACGIH TLV: 10 MG/M3 TDUST
Proprietary: NO
Ingredient: CHROMIUM/AZO DYE COMPLEX
Ingredient Sequence Number: 05
Percent: <1%
NIOSH (RTECS) Number: 1004139DY
CAS Number: 84179-66-8
Physical/Chemical Characteristics
Appearance And Odor: BLACK POWDER / FAINT ODOR.
Specific Gravity: 1.7
Decomposition Temperature: UNKNOWN
Evaporation Rate And Ref: NEGLIGIBLE
Corrosion Rate (IPY): UNKNOWN
Fire and Explosion Hazard Data
Flash Point: NOT APPLICABLE
Extinguishing Media: WATER, DRY CHEMICAL, CARBON DIOXIDE OR FOAM.
Special Fire Fighting Proc: AVOID INHALATION OF SMOKE. WEAR PROTECTIVE
CLOTHING AND SELF-CONTAINED BREATHING APPARATUS.
Unusual Fire And Expl Hazrds: TONER IS A COMBUSTIBLE POWDER. LIKE MOST
ORGANIC MATERIALS IN POWDER FORM, WHEN DISPERSED IN AIR, IT CAN FORM
EXPLOSIVE MIXTURES.
Reactivity Data
Stability: YES
Cond To Avoid (Stability): NONE SPECIFIED BY MANUFACTURER.
Materials To Avoid: NONE KNOWN.
Hazardous Decomp Products: PRODUCTS OF COMBUSTION MAY BE TOXIC. AVOID
BREATHING SMOKE.
Hazardous Poly Occur: NO
Conditions To Avoid (Poly): NOT APPLICABLE
Health Hazard Data
LD50-LC50 Mixture: ORAL LD50 (RAT) IS >5 G/KG
Route Of Entry - Inhalation: YES
Route Of Entry - Skin: NO
Route Of Entry - Ingestion: NO
Health Haz Acute And Chronic: MINIMAL RESPIRATORY TRACT IRRITATION MAY
OCCUR AS WITH EXPOSURE TO LARGE AMOUNTS OF ANY NON-TOXIC DUST.
Carcinogenicity - NTP: NO
Carcinogenicity - IARC: NO
Carcinogenicity - OSHA: NO
Explanation Carcinogenicity: THIS MATERIAL IS NOT A CARCINOGEN.
Signs/Symptoms Of Overexp: NONE SPECIFIED BY MANUFACTURER.
Med Cond Aggravated By Exp: NONE WHEN USED AS DESCRIBED BY PRODUCT
LITERATURE.
Emergency/First Aid Proc: EYES-FLUSH WITH WATER. SKIN-WASH WITH SOAP AND
WATER. INHALATION-REMOVE FROM EXPOSURE. INGESTION-DILUTE STOMACH CONTENTS
WITH SEVERAL GLASSES OF WATER.
Precautions for Safe Handling and Use
Steps If Matl Released/Spill: SWEEP UP OR VACUUM SPILLED TONER & CAREFULLY
TRANSFER INTO A SEALABLE WASTE CONTAINER. SWEEP SLOWLY TO MINIMIZE
GENERATION OF DUST DURING CLEAN-UP. RESIDUE CAN BE REMOVED WITH SOAP & COLD
WATER. USE A DUST TIGHT VACUUM MOTOR.
Waste Disposal Method: WHEN DISPOSED, THIS MATERIAL IS NOT A HAZARDOUS
WASTE ACCORDING TO FEDERAL REGULATIONS. HOWEVER, STATE/LOCAL REQUIREMENTS
MAY BE MORE RESTRICTIVE. CONSULT WITH APPROPIATE STATE/LOCAL WASTE DISPOSAL
AUTHORITIES.
Precautions-Handling/Storing: USE WITH ADEQUATE VENTILATION.
Other Precautions: AVOID PROLONGED INHALATION OF EXCESSIVE DUST.
Control Measures
Respiratory Protection: NONE REQUIRED WHEN USED AS INTENDED IN XEROX
EQUIPMENT.
Ventilation: USE WITH ADEQUATE VENTILATION.
Protective Gloves: NONE REQUIRED WHEN USED AS INTENDED
Eye Protection: NONE REQUIRED WHEN USED AS INTENDED
Other Protective Equipment: NONE REQUIRED WHEN USED AS INTENDED IN XEROX
EQUIPMENT.
Work Hygienic Practices: NONE SPECIFIED BY MANUFACTURER.
Suppl. Safety & Health Data: FOR USE OTHER THAN NORMAL CUSTOMER -
OPERATING PROCEDURES (SUCH AS IN BULK TONER PROCESSING FACILITIES) GOGGLES
AND RESPIRATORS MAY BE REQUIRED. FOR MORE INFORMATION, CONTACT XEROX.
Transportation Data
Trans Data Review Date: 92139
DOT PSN Code: ZZZ
DOT Proper Shipping Name: NOT REGULATED BY THIS MODE OF TRANSPORTATION
IMO PSN Code: ZZZ
IMO Proper Shipping Name: NOT REGULATED FOR THIS MODE OF TRANSPORTATION
IATA PSN Code: ZZZ
IATA Proper Shipping Name: NOT REGULATED BY THIS MODE OF TRANSPORTATION
AFI PSN Code: ZZZ
AFI Prop. Shipping Name: NOT REGULATED BY THIS MODE OF TRANSPORTATION
MMAC Code: NR
Disposal Data
Label Data
Label Required: YES
Technical Review Date: 18MAY92
MFR Label Number: UNKNOWN
Label Status: F
Common Name: TONER/DEVELOPER CARTRIDGE/DRY INK CARTRIDGE, P/N
6R281
Chronic Hazard: NO
Signal Word: CAUTION!
Acute Health Hazard-Slight: X
Contact Hazard-None: X
Fire Hazard-None: X
Reactivity Hazard-None: X
Special Hazard Precautions: MINIMAL RESPIRATORY TRACT IRRITATION MAY OCCUR
AS WITH EXPOSURE TO LARGE AMOUNTS OF ANY NON-TOXIC DUST. USE WITH ADEQUATE
VENTILATION. FIRST AID: EYES-FLUSH WITH WATER. SKIN-WASH WITH SOAP AND
Label Name: XEROX CORP
Label Street: XEROX SQ, 100 CLINTON AVE S
Label City: ROCHESTER
Label State: NY
Label Zip Code: 14644-1877
Label Country: US
Label Emergency Number: 716-422-2177 (XEROX CORP, NY)
URL for this msds If you wish to change, add to, or
delete information in this archive please sent updates to dan@hazard.com.
Myles,
Are you sure this is an inkjet ink? It looks more like a dry toner for copiers.
If you want specific info on inkjet inks, try searching for some patents. I believe you have to pay now to see the complete patent text but at least you can get started with the first page.
There are a lot of types of inks: water based, solvent based, UV-curable...
Greetings,
Olivier
can somebody please tell me the composition of a standard inkjet printer's ink(black). the dye and the solvent at least.
akku555@rediffmail.com
First, what is your objective for the ink? Then you can information about the ink that fits that objective. Otherwise, there are many options as to what is in the ink for inkjets.
The best source for inkjet composition is the manufacturer of the ink; HP, Epson, Brother, IBM, etc. Ask for the MSDS and they must give it to anyone in industry. There are many dyes, inks, solvents, pigments with different characteristics for UV resistance, water or oil resistance, durability, drying speed, resistance to spreading out (big problem with eary inks for inkjets).
I think that ink jet inks are water based with solid pigments. They also use glycol to slow down evaporation
