Boiler efficiency would decrease - you would be having to waste energy heating the steam you are injecting and then sending out of the stack (meaning less heat going to the tubes). As Chicopee points out, atomizing steam is typically used for burning oils, but even in that case, the steam is carefully tuned to ensure you aren't introducing an excessive amount for the same reason.
