racerdude
Specifier/Regulator
- Aug 23, 2005
- 23
In my last post Greg and Norm got me to understand the IC on a GM torque arm suspension. I think I am up to speed in the IC,thanks Norm and Greg.
I am still failing to understand what the TA height(raising or lowering) does to the IC when you have parallel lines with the LCA's or they just wont intersect for a mile.
If you raise the TA from the stock imaginary line or lower it what does it do to the IC if ya also move the LCA's so it's line is parallel with the TA change and the perpendicular line off of the nose of the TA is not moved much.What do you use for a reference point the CG? Or the anti squat line?
What does all this do to weight transfer an a drag car? You might want to refer to my previous post also.
THANKS
Larry.
THANKS
Larry.
