info config.pro
  • Thread starter Thread starter xcad
  • Start date Start date
X
xcad
Guest
Hello pro/e users
Below i want to mention some hidden config options that refers to Proe 2001 :
sketcher_3d_drag (yes or no) : if set to yes proe allows you to dynamically drag the profiles in a section when you modify a section.
sketcher_dynamic_dimensions (yes or no) : if you set no, when you modify a dimension the system changes the dimension, moves the section to the new position but shows and the previous situation of the sketcher (repaint or Ctrl+left button). Also the system acts different (interface) when you modify a value of a dimension (try it !).
sketcher_old_default_grid : (yes or no) : displays the old grid when you enter the sketcher environment
As high-end cad software pro/e has a lot of configurations (hidden or not) for someone to change in order to make pro/e more friendly and efficient for our work
xcad
thank u xcad
