Dear all,
Iam working on in-flight strain analysis and for some reasons unable to match (not even reasonably) the in-flight strain recorded by the strain gauges. Assuming that the strain gauges are bonded properly and the inflight strain data are correct.
I have got few doubts like…
At maximum ‘g’ (normal acceleration ), maximum strain should be registered by all the strain gauges and conversely the maximum strain recorded throughout the sortie should be at maximum ‘g’ and in either case it is supposed to be the same strain gauge.
The strain gauges close to the cg of the aircraft should experience more strain…like the once put on the longerons and shear wall..
Irrespective of the maneuver, is it just ‘g’ which determines the load on the aircraft, or else pitch acceleration should be considered while evaluating strain on fuselage (as fuselage is most loaded in pull-out) & roll acceleration for wing
If any literature or papers is available kindly suggest me
Thanks in advance
with kindest regards,
shearlag
Thanks in advance
shearlag
