TalGed
- May 16, 2006
- 7
I am trying to construct formwork for concrete wall, I used plywood coated with steel, I am using UPVC conduit as spacer, and rebar 8mm as a connector, I am trying to design the lock at the end of rebar, so it will use principal of "clin" knok it to lock and knok again to un-lock. Do you have better idea, this system is "idiot proof" in my opinion, I tried to use bolts 80-90% were lost after first casting?
