i have a problem with an induction motor come generator, the unit is engine driven,it flashes a small dc voltage into the winding every time the engine is run,the motor is used as a motor when hooked up to the mains,but when driven by the engine is used to power heater bars in a fridge unit,can any one tell me what exactly allows this motor to generate power,assuming the dc voltage excites the motor and three capacitors are used for smoothing the generated voltage,the unit in particular in question will not generate, the capacitors are all good and dc voltage is being injected into the motor winding. Any information to this problem greatly received.
