Hello Guys,
I agree that residual stress are compressive and they usually increase the material strength but only when the external load in the body creates tensile stresses. An example that comes to mindis the material yielding of a pressure vessel that will create residual stress. I realize that MECHANICAmay not bethe right tool to use, for the problem you have Daniel. But ifMECHANICA is the only FEAprogram you have available then assumption and safety factors, must be included in your model.
The following comments are purely academical and only reflect my understanding of the problemgiven the information so far provided. The external load apply to the shaft will create shear Stress ( I assume this is a torsional shaft). If we combinethe residualcompressive stresses with the shear stress of the external loadthe result will be an increaseon themaximum shear stress in the shaft or no significant change will be observed. if the residual stress magnitude is grater in magnitude that the torsion shaft shear stress the Maximum principal shear stress will increase. In the other hand, if the torsional shear stress is much greater than the residual stress the maximum shear stress does not change by much.Therefore, forthe state of stress provided by Daniel's problemthe residual stress does not help but may actually have a decremental effect. Hereare someexamples:
Sxx= Residual Stress, Sxy= Shear torsional stress
|Sxx|>|Sxy|
let's assume that the residual stress is Sx=-1000 psi and the shear do to the torsion of the shaft is Sxy=500 psi the maximum shear stress for this stress combination will be 707 psi. In this case the maximum principal shear stress is increase from 500 psi to 707 psi. There was an increase of 41%.
let's reverse the numbers |Sxx|<|Sxy| Sxx= 500 psi and Sxy=-1000 psi.
In this case the Maximum Principal shear increased from Sxy=1000 psi to Sxymax=1030 psi. The increase was less than 1% in the Maximum Shear Stress. Therefore, what these two example show is how residual stress may increase or may not have much of an effect in the shaft Maximum shear stress.
Daniel you mention that the results you got from the model using the two volumes were not very good. Could you elaborate more about what you meant with that?
Luis
By the way if you want to try the Morh's circle program in the web here is the URL:
http://web.umr.edu/~medialab/fipse/preview/Philpot/mohr_stre ss/a_draw.htm
Edited by: Luis Aguirre
