chez311,
I'm not sure about the connections to simultaneous requirements here - I think this is very shaky ground.
We have examples in the position section where nX INDIVIDUALLY is applied to FCF's that reference a datum feature that is also nX INDIVIDUALLY. The datum features are considered individually, so simultaneous requirements does not apply.
There is also an example in the profile section (Fig. 8-23) where nX and INDIVIDUALLY are applied to a FCF that has no datum feature references. So simultaneous requirements does not apply here either.
Let's look at different variations of the upper FCF from Fig. 8-23:
2X SPF|0.1
The 2 zones must be evaluated in the same alignment, because the 2X creates a pattern
2X SPF|0.1 INDIVIDUALLY
The 2 zones do not need to be evaluated in the same alignment, because INDIVIDUALLY cancels the pattern creation
SPF|0.1,,,,,,,,,,SPF|0.1 (2 different FCF's)
The 2 zones do not need to be evaluated in the same alignment, because there is nothing to create a pattern and simultaneous requirements does not apply
SPF|0.1|A,,,,,,,,,,SPF|0.1|A
The 2 zones must be evaluated in the same alignment, because of simultaneous requirements
SPF|0.1|A SEP REQT,,,,,,,,,,SPF|0.1|A SEP REQT
The 2 zones do not need to be evaluated in the same alignment, because SEP REQT cancels the simultaneous requirement
2X SPF|0.1|A
The 2 zones must be evaluated in the same alignment, because the 2X creates a pattern and because of simultaneous requirements
2X SPF|0.1|A INDIVIDUALLY
Do the 2 zones need to be evaluated in the same alignment? INDIVIDUALLY cancels the pattern creation, but is there still a simultaneous requirement?
Does it even make sense to specify INDIVIDUALLY in a situation where simultaneous requirements applies?
Evan Janeshewski
Axymetrix Quality Engineering Inc.
