daveparkinson
- Mar 13, 2008
- 63
I am developing a configurable body of a steel wagon body that my company manufactures. It is similar to a big metal tub with a door on the back.
When I increase the length of the body, there is a rail alongside the body which increases to suit. The rail has slots cut into it in a linear pattern spaced at 300mm; the slots are in place so that we can easily locate a side panel.
The slots are spaced 150mm from either end of the rail. Although this value is not imperative.
When I increase the length of the body, and therefore the length of the rail, I want the instances in the pattern to increase to suit the new length.
Anyone have any reccomendation on how to do this?
I can not simply increase the space between the slots and keep the same number of instances, as this was my thought by using a sketch driven pattern.
