OperaHouse
I've been watching for a while and haven't seen much on the general rules for running a VFD at higher than 60Hz. Even the basic ones go to 240 and others go many times that. What is the general rule for drop in power? Should this be avoided with older motors because of bearing issues? For this discussion let's avoid the mechanical issues that you can get into with gear boxes.
