I am building a chain drive version of a geared "two man hand powered rice huller" for the Maine Rice Growing Project. I'm copying a Japanese made impact type huller that works well.
Initially the idea of using sprockets and chain seemed feasible to increase the speed from a manual input of 75rpm raised to 2500rpm in two stages. When the forces to operate it seemed high, I wondered if there were inherent issues with using chain drive to increase speed rather than reduction which is more common...I designed conveyors for sawmill operations...
Without the chain, all parts are free to rotate, but the chain is a major load issue. On a whim, I just rinsed the grease out of the chain with mineral spirits and the load was much lighter, so I am pursuing a friction reducing strategy. I recently accessed an old thread here thread406-63684 which began to address this issue, and I'd like to take it further.
1. What chain lube would be a probable replacement for the Chinese grease? For the chain, I'm thinking a real good rinse of the old stuff, and some high tech teflon or ceramic based oil...think tour de France.
2. Are cheap Chinese chains that much worse for friction than a Tsubaki or other better grade chains?
3. Since loads are relatively low, are there strategies for pushing/flushing out the Chinese grease in the pillow block ball bearings and introducing a lighter synthetic grease, or introducing a high tech oil, or running them almost dry with a high tech oil?
Thanks for any ideas/inquiries.
Colin
Colin
