Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Belanger said:I would say that your datums B and C are not directly opposed, so they are not covered by Rule #1 and thus they get the general profile tolerance.
axym said:Datum features B and C on the L-shaped part drawing are not features of size, because the datum feature labels are not directly in line with the dimension lines.
axym said:axym (Industrial)
15 Sep 15 17:00
greenimi,
I'm glad that the thread is getting to some interesting outcomes. Your questions tend to make us dig deep and extract the subtle details. Keep in mind that the writers of GD&T textbooks and exercise books (and even standards) can only get into the intricacies to a certain extent, without losing most of their audience. People want things to be simple and easy, not complicated and difficult. I know from experience that it is much easier to make money glossing over these subtleties than it is addressing them. I'll stop there before I get into a self-righteous, bitter rant ;^).
CH,
I would say that Rule #1 still applies, even with features that are not perfectly opposed. Assessing the feature's conformance to a boundary is straightforward, even if the feature has unopposed areas.
Again, to me the difficulty lies in the actual local size. It's an old, shop-worn tolerancing tool that serves well for parts that one wants to be able to inspect with a caliper or mic. But for this tool to work, certain conditions have to be in place (such as opposed geometry, and form error that is relatively small). When these conditions are not satisfied, it breaks down and becomes ambiguous. It's just not as robust as zone-based geometric tolerances.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
Kedu said:Why those two datum features (which lets pretend are not covered by rule#1) are getting the general profile?
Rule #1 is by definition a way of controlling form. So if Rule #1 does not apply on a particular feature, we appeal to another form tolerance (unless it's an independency thing, which is not pertinent to your example).Kedu said:Also, what rule#1 has to do with the enforcement of the UOS (default profile) onto the datum features B and C?
Pmarc said:... Couldn't the general profile be still applicable to datum faces B and C as an orientation (not form) control
chez311 said:I would agree, taking into account Y14.5-2018 para 5.2(c) the basic dimensions associated with profile tolerances in fig 7-40 would seem to fall under directly toleranced dimensions (A and C, for whatever reason B still lacks an applied tolerance - geometric or +/-).
As a general question to all,
Considering the broad definition in Y14.5-2009 para 2.2 and Y14.5-2018 para 5.2 for directly toleranced dimensions, what kind of tolerances would NOT fall under "direct tolerancing methods" ? I am thinking general tolerances applied in a note like the ones above (UOS 0.5 profile to |A|B|C| ) or a general tolerance specified in the title block (such as x.xx +/-0.05 for 2 decimal place dimensions).
Also, I would say that there is a difference between directly toleranced dimension, as defined in 3.27 and paras. 5.2 (a) & (b), and directly toleranced feature, as defined in para. 5.2 (c) and used in the definitions of both types of iFOS in 3.35.1. An example of the latter is a rectangular hole fully defined with basic dimensions and controlled with an all around profile tolerance; there is no directly toleranced dimension used in that definition but the feature itself is directly toleranced.
chez311 said:As far as setting B@MMB the effects would depend on what version you were using. In Y14.5-2009 datum features modified at MMB which do not fully "capture" the part/feature like fig 4-31(c) are required to make contact with the simulator. In Y14.5-2018 the same type of features are no longer required to make contact with the simulator see fig 7-36 as long as "one or more extremities shall remain between the MMB and the LMB". Since in both of these cases the simulator is fixed at MMB presumably the entire tolerance zone exists on one side of the simulator (entire tolerance zone available) instead of equally disposed on either side as the default in the RMB case (half the tolerance zone available), it surely doesn't say that anywhere explicitly even in 2018 but I think thats not too big of a leap to make. That said, with the contact required in 2009 the amount of the tolerance zone used depends on variation of the surface and in 2018 I'm having a hard time envisioning the consequences of a datum feature used to establish its own tolerance zone and is allowed to migrate away from itself as long as "one or more extremities shall remain between the MMB and the LMB". For the latter case I guess the entire surface is still required to be within the LMB/MMB instead of just the extremities.
Anyhow - I'm not sure the addition of the MMB modifier is a good solution to the problem of not being able to utilize the full tolerance zone. The standard presents an alternate case (and indeed, has been known as a solution some time before written into the standard) of utilizing a unilateral tolerance zone with the entire tolerance zone biased inside the material of the feature. This is stated in Y14.5-2018 para 11.4.3.1(b). Unfortunately as pointed out in the thread I referenced above, no figures are presented to show this alternate solution in the new standard.
