Jonnypaul89
Geotechnical
- Apr 29, 2016
- 2
Hi All,
I am having trouble with some erroneous readings from two boreholes that are fitted with inclinometers. The Inclinometer probe skips out of the tracks when I reel it up to the top of the casing.
I expect that the problem relates to poor installation. My inital thought is that the casing that the contractor has used is not adequate/ the grooves are not deep enough.
I know that the readings I am getting are incorrect because other older inclinometers that are installed at the site are not showing excessive movement.
Can anyone recommend tried and tested inclinometer tubing that will hold the probe within its tracks?
Thanks in advance
Thanks in advance
