I am looking to set up a test apparatus in order to test some motion sensors. The entire unit under test will weigh < 1/3 lb.
The requirement is to have a repeatable test in terms of velocity and acceleration that are about the speed of human handling.
Rotation required is about rotation per second.
The first idea was to use a servo driven rotary stage but
cost will be about $7k for the rotary stage, servo and controller. Then... to expand the setup by adding more linear stages.
There are so many robotic and control companies around, where can I start looking for a lower cost solution.
Thanks in advance.
Thanks in advance.
