CAD Application Support
Hi All,
is there a way in NX to create some sort of "selection rule" for example "select all faces of size 5mm, or select all faces on defined plane?
If this is not currently possible, is there anyone who has some kind of tool which would do that? Idea is to select the faces or solids based on parameter provided by user and change color .
Thank you in advance.
