Greglock: I'm sorry I didn't clarify the statement about freon, here it is from my previous post:
"freon, when leaked into an internal combustion engine makes something close to nerve gas, which would have made this a real crowd pleaser if something went wrong."
That's what I was referring to when I said the freon could possibly hurt someone. And no, I haven't done any research on normal freon since I never use the stuff. And also no, I don't have any proof about freon winding up being toxic if leaked into the engine. Try it out and let me know if you die or get sick
Spereira: As for the upgraded alternator, it's no larger than the normal, just bigger/better windings and you get extra power. No extra pulleys/larger pulleys needed, also, no extra drag on the engine. Like I said, it's a trick that a lot of guys use to get those extra amps for the big stereo systems.
I was speaking of adding the HE's into the IC, not after it, but inside it. No extra intake piping, so no extra pressure drop inside the IC right?.
Also, if you enlarged the A/C circulation system and added more coolant, why would it bother the compressor? As long as the compressor has the factory spec coolant pressure, it will continue to push the coolant through at the factory preset velocity. Granted, with a larger system that means the coolant has more time in the tubing, therefore the refrigerant would have more time to heat up. So possibly some problems there. What do you think?
My main idea is to not have a traditional IC. Since all that extra piping from the filter, thru the IC, to the intake plenum adds lots of weight and lots of time for the air to heat back up. I'll use a turbo engine as an example: My main thought was to go directly from the turbo to the intake plenum with a larger diameter than normal round tube. Stack 5 or 6 small HE's in there (they can't have too many fins of they will restrict airflow too much) and push the coolant through there at the best velocity for maximum cooling. Less piping from turbo to engine results in less turbo lag, and this setup may be efficient enough to justify running a compressor for the coolant full-time. Maybe it'd be easier to place in tight places for after-market tuning as well. What do you think?
