Importing Solidworks Files
sg20
Can anyone tell me a way to import a Solidworks file. Thanks in advance for your help.
I believe transmagic will read a .sldprt and output a .ipt but it is not a cheap program. Otherwise you can export the file from SW as a SAT or STEP.
David
Thanks David.
I would use STEP (*.stp) output. If you use ACIS (*.sat) make sure to click Options in SWX and set as v7.
You could also try this new translator for Parasolid files from SWX.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
Also, make sure it exports as a solid body. If not you won't be able to mate to it.
