Dec 23, 2002 #1 A aghiotti Guest i'm modelling with the blen d function in proe, but, since i have got the point of the different sections in txt format, i want to import them. can anyone help me? thanks
Dec 23, 2002 Thread starter #2 D dougr Guest Create an ibl file, this be used to generate points datum-curves or blend features (surface or solid). You can organise your data on a spreadsheet and save as a txt file, then rename file to have .ibl extension. Search your help documentation for blend files..
