Import of native NX assembly into TC
c0pp3r
I am struggling to get a downloaded Destaco clamp imported into our Teamcenter installation. I am attempting to use the import assembly into TC command and navigating the various options that are available within it. My failure mode is related to default user/group. What is the format for this?
NX7.5/TC 8.3
Thanks.
Matt Smith, Principal Designer
(o) 937.456.8728
1219 US 35 West P.O. Box 60
Eaton, OH 45320
msmith@hennypenny.com | www.hennypenny.com
 http://files.engineering.com/getfile.aspx?folder=2c1142b8-8661-48f1-88a6-a82aec5a6ed4&file=import_error.JPG
Screen capture of current ownership format attached... whats missing or needs to change?
(o) 937.456.8728
Eaton, OH 45320
 http://files.engineering.com/getfile.aspx?folder=807e1b9b-b9c1-4f8c-809f-fe9ae48ccf52&file=ownership.JPG
Did you have a look in the helpfiles?
I would say (looking at how the folder path is written) the . should be : But I can be wrong...
I always change ownership after importing...
Ronald van den Broek
Application Specialist
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
nutace - Thanks for the response.
Yeah - I looked through the help files. The ownership section is really vague. I tried a colon in place of the . and the error persists.
You mentioned that you typically change ownership after the import... how are you avoiding this? I am being forced to provide it. Or at least that's how I am interpreting the error feedback I'm getting. Maybe that's not my issue???
(o) 937.456.8728
Eaton, OH 45320
There is no need to provide it when importing. Just leave them empty.
Anything you import will be with your ownership in the group you are logged on to.
Senior Application Engineer
NX8.5.3 / TC9.1.2
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
