Import .odb results using *Amplitude
danieljgalles
10
I would like to use the temperature results from a .odb file as input into a new simulation. I can do this by specifying
*Temperature, file=<path for .odb>, bstep=<step in the .odb to read the temperatures>
Then, I just create a step at each time I want to import another temperature field. What I want to do, though, is import several temperature fields within a single step. It seems like I should be able to use *Amplitude to accomplish this, but I haven't been able to figure it out. Does anyone know if this can be done?
Thanks,
Daniel
