1
- #1
hootrpootr
Aerospace
First of all, I’d like to apologize for any misleading information or confusion I may cause, as this is a topic I’m very unfamiliar with.
Basically, a customer provided me with a set of files with which to create and run a model using Patran with Nastran.
All of the files except one make sense: patran database file, load cases bdf, loads bdf, etc. The one file that I know nothing about is a .pch file that contains lines of code referring to “dmig kaax”, “dmig paax”, and referencing various nodes in the model. I know that the nodes are all interface points that connect one major structural assembly to another. And based on a google search, I’m under the impression this .pch file has something to do with the stiffness matrices at the nodes.
I hope this is enough info to go off of, but is a .pch file something that is exported out of a database, or something I can import into one? If it’s the latter, how could I accomplish this?
Thanks!
Thanks!
