Hi All,
I am looking at a very large Nastran model in .bdf format. I have imported into Abaqus and tried to run a frequency analysis. The error message is returned that material properties are missing from about ~1% of the elements (7000 in total).
I have looked at the ErrElemMissingSection in the ODB and they seem to be distributed throughout the model. I am assuming that this is an error when importing the BDF, and I will have to go in and manually assign sections / material properties to these elements. Is there any easy way of doing this?
Is it possible to export the element set ErrElemMissingSection from the ODB and import it into the CAE file so I can then assign material properties to that set??
Any advice would be much appreciated.
Nigel
Nigel
