asfede
- Jul 10, 2007
- 15
Hello, sorry for my poor English.
I need to know if you can import a file. Dwg 3D made in autocad solidworks to work?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
SW Help said:To open an MDT file:
Click Open (Standard toolbar) or File, Open.
In the dialog box, set Files of type to DXF (*.dxf) or DWG (*.dwg), browse to a file, then click Open.
In the DXF/DWG Import Wizard, select Import MDT data from file (imports as parts, assemblies and/or drawings), then click Next.
[red]If you do not have Mechanical Desktop installed, the option to import MDT data is not available.[/red]
On the Document Settings screen, select options for the Model and layout tabs, then click Finish.
SW Help said:To open a DXF 3D part:
Click File, Open.
Set Files of type to DXF (*.dxf).
Browse to a file, then click Open.
The model is converted immediately into a SolidWorks part, or the DXF/DWG Import Wizard appears.
In the DXF/DWG Import Wizard, select Import to a new part, then click Next.
On the Drawing Layer Mapping tab, click Next.
On the Document Settings tab, select Import this sheet and as 3D curves/model, then click Finish.
