Jun 17, 2010 #1 I intogtar Guest Hi all! Is there any way to import 3D/2D project from CATIA V5 to AutoCAD 2011? Thank you!
Jul 14, 2010 Thread starter #2 F firebreather Guest You can save the data as .igs (3D data) and .ig2 (2D drawings) in CATIA, and import into AutoCAD.
Jul 27, 2010 Thread starter #3 P Prakash G Kotagond Guest Save CATIA drawing as .dxf file & import in AutoCAd.
Aug 12, 2010 Thread starter #5 H halzimers Guest When you save as in igs file, make sure you go into the compatability options and choose between solid shell, surface, or wireframe.
