Import CATIA file to AutoCAD
  • Thread starter Thread starter intogtar
  • Start date Start date
I
intogtar
Guest
Hi all!
Is there any way to import 3D/2D project from CATIA V5 to AutoCAD 2011?
Thank you!
You can save the data as .igs (3D data) and .ig2 (2D drawings) in CATIA, and import into AutoCAD.
Save CATIA drawing as .dxf file & import in AutoCAd.
the version of autoCAD is required.
When you save as in igs file, make sure you go into the compatability options and choose between solid shell, surface, or wireframe.
