*imperfection 1
mambo5
71
hi,
i want to add imperfection on my node, i have the following input;
*IMPERFECTION, SYSTEM=R
axial, 1, 0, 2250
i got the following error;
***ERROR: NODE NUMBERS MUST BE POSITIVE INTEGERS
LINE IMAGE: ASSEMBLY_AXIAL, 1, 0, 2250
what went wrong with my input, i'd defined my node number in the nset=axial, don't understand if i still need to define in the '*imperfection'?
please advise.
According to the docs, you can only specify a node number, not a node set. You will have to put the node number in the *IMPERFECTION card, not an *NSET name.
Martin Stokes CEng MIMechE
i did try to put the node number in the *IMPERFECTION card, not an *NSET name also, i still got error;
***ERROR: in keyword *IMPERFECTION, file "3.inp", line 7601: Unknown assembly id 159.
which 159 is my node number.
wondering can i apply 'imperfection' in CAE? as I not see in which module i can do this. please advise.
According to the keyword docs, *IMPERFECTION is model data, so must be specified in the appropriate *PART definition. I suspect that you have tried to define it within *ASSEMBLY.
Also, *IMPERFECTION is not supported by CAE, at least not according to the v6.7 docs, so you will have to add the keyword manually.
i moved the *imperfection just before the *end part, i still got error;
***ERROR: in keyword *IMPERFECTION, file "3.inp", line 2735: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): model
My mistake, I thought it could only go in the *PART definition :). I've since found an input deck where I used *IMPERFECTION, and I put the keyword after the *END ASSEMBLY card and before the *STEP.
still got error after i moved *imperfection after *end assembly and before the *step,
***ERROR: in keyword *IMPERFECTION, file "3.inp", line 5452: Unknown assembly id 159.
You need to make sure that you have correctly identified the node. If node 159 is in an instance called Part_1, then you must reference it as Part_1.159.
THANKS Martin Stokes,
IT's working now.
