Jet fuel distribution at the airport should not require any special materials for the jet fuel or av gas itself. Personally, I don't think you should be worried about impeller bits either as there is much more danger from contamination during the last truck haul or last pipeline transport, or last tank contamination, than what you would ever have from a flake or two off an impeller of any kind of material.
Interestingly enough I have found one obscure reference to the US Army mobile field AC fuel delivery pumps being supplied with brass impellers, but with no reason given, Static electricity?? I also note that in addition to carbon steel, they will use stainless, aluminum and FRP pipelines too (for weight restrictions delivering to field and easier field handling I presume). Still the product will probably be filtered again on the truck delivering to the aircraft's tank. I think SS piping may be more for corrosion protection from exterior sources, taxi-way salt for ice control, de-icing spray drips and simply ease of maintenance (no paint required) to keep up presentation. Seems to be favored by USAF. There should be no chemical or physical requirement for SS or brass internals for fuel pumps, however with that USArmy pump, that should be qualified with IF they are not required for some anti-static electricity reason.
I don't get involved with final distribution at the airport, but I know that anti-static treatments (Static Dissipater Addatives, SDA) are chemical additives that must be added after the last terminal tank (pumping tends to disassociate that chemical) and is used with JP-8 = Jet A= Jet A1. It is not added to JP-5 (US Navy), so the practice there is totally relying on limiting fill velocities to < 1 m/sec and doing slow fills (filling >10 minutes), bottom tank loading, static grounding are common handling techniques, as is the case for all aviation fuels, due to both the possible build up of static on the AC and the fuels too (which can reach 50 kV). "Relaxation" by letting freshly pumped fuel sit in tanks for 30 minutes or so, I believe is also common, especially in cold dry climates, so I wouldn't eliminate that practice. With the newer fuels and additives, I think some of that practice might be left over from previous days when AC fuels were more explosive, but with up to 50 kV possible, I certainly won't say its not worth continuing to do it.
It would be interesting to find out if the pump vendors do not routinely supply brass to other AV fuel clients. Could let us know what you find out there?
BigInch
![[worm] [worm] [worm]](/data/assets/smilies/worm.gif)
-born in the trenches.
