Trying to determine the impact force from an object falling from multiple stories . . . we will have a wood platform that we need to design so that it stops the object. To refresh everyones' memory, the average force is called "impulse" and is equal to the change in momentum divided by the time that momentum takes to change. There is no good, easy way to determine how long it takes the object to come to a stop (exceedingly complicated), so it is next to impossible to get an acurate force with the impulse method. I was wondering if I could skip all of that and go straight from the initial potential energy (or final kinetic energy if you would prefer) and convert that energy into a moment, or a deflection, in the wood beam?
The other issue deals with using wood to resist this high impact force. Safety cages and air bags in cars are deformable and help lengthen out the time for the momentum to change, which reduces the force. A simple wood beam wouldn't be a material that would lend itself to high, energy absorbing deflections, but would break catastrophically. I was wondering if it wouldn't be a good idea to simply let the wood break (absorbing the energy), and have some heavy construction netting beneath the wood structure to catch/reinforce the falling object/broken wood beam.
I can't remember where I was (either in Las Vegas, NV or Vancouver, British Columbia), but I have walked adjacent to high rise construction on public sidewalks, underneath wood canopies that were placed to protect the general public from falling debris. I just was wondering about some input from somebody who has designed one of these protection structures.
