engpes
- Feb 10, 2010
- 175
I am trying to determine the net impact force for a falling object has (8x10 structural frame)from 2 inches off of the ground. I know the mass of the frame and I can calculate the energy balance if I can determine the deceleration time.
Is there any published data / constants that can relate the falling velocity & weight of an object to its deceleration time when impacted against a particular material (say wood or concrete)?
May frame is about 5,000 lbs and will be dropped onto a wooden deck. This could also be assumed rigid for simplicity's sake. I am stuck when trying to determine with the deceleration time will be?
Thank you in advance for your help!
