Image file from NXOpen/Journal 1
Guillermo391
MX
I have tried searching the documentation for this, but I'm relatively new to this (student working part time on new project)...
Is there any way I can call to open an image file from within the Journal? Reason is it asks for input from user, but I'm required to graphically show the user what is the required info to reduce errors. Is there some way I can make this happen?
Thanks,
Guillermo391
You have an image file (such as .bmp, .jpg, or .png) and simply want to open it to display it to the user?
If so, the following is probably the easiest way to do it (only uses .net functionality, no NXOpen functions required).
Code:
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        'image file to open
        Dim myImage As String = "{replace with path to your image file}"
        Try
            System.Diagnostics.Process.Start(myImage)
        Catch ex As Exception
            'handle error
        End Try
    End Sub
End Module
www.nxjournaling.com
If you are using the block styler, you can add an image to your NX dialog to serve as a legend.
Mark Rief
Product Manager
Siemens PLM
