after issueing a SBCTRAN command, the variable Surface Load field should display as follows:
- if it is defined by simple gradient, then it displays as colored contours (check that under "plot controls" -> symbols, the plot of surface loads is set to "pressures")
- if it is defined by table or function, then it displays in uniform gray, in preprocessor. In order to see it "processed", you have to enter POST1 and replot after having enabled "plot controls -> symbols -> surface loads -> pressures".
