I posted a problem before about the external translators not properly exporting assemblies with more than 2 levels. I've been doing some more experimentation and found that if I export an assembly in UG (NX5) using the "Entire Part" option, I get the same result as when I use the external translator (i.e. the assembly exports, but everything beyond the second level is missing and I have tried every combination of loadoptions.def settings with no luck). However, if instead of "Entire Part" I choose "Selected Objects", and then manually select the assembly, everythinjg exports fine. So I just wanted to know what the difference was when exporting Entire Part or Selected Objects, because that might shed some light on the problem. I looks to me that when "Selected Objects" is used, a temporary part file is created and exported.
Thanks.
Thanks.
