I'm not sure that's exactly accurate. What I do know is that when cranking an engine, most 12 volt batteries drop down to about 10 volts, so the coils were designed to make full output voltage from 9-10 volts. Once the engine is running, the voltage rises up to 13 or more and to prevent overheating the coil, the ballast resister drops the volage. Note, the resistor is bypassed when the key is in the start position. A burned out resistor was infamous for a car that would fire up while cranking and immediately quit when the key was released.
I'm sure different cars, number of cylinders, etc. dictated differant part numbers. Most of today's cars have the ignition controlled by the ECM, so the dwell (charging) time can be adjusted as necessary for a hot spark without damaging the coil(s). Of course this level of interdependence probably increases the variations and amount of part numbers.
