If slope is vertical then ? 2
Chunil
Geotechnical
KR
If slope is vertical then can anybody suggest it's vertical tollerence for STABL.
Like Caission for container yard quay , how can solve the slope problem with STABL...
U know SLOPE/W cannot calculate if it is vertical.
It can cause a error !
It is same on STABL ...I think,..,.
CAn anybody suggest it's tolerence ?
I usually set the top of the vertical wall (slope) back about 0.1 foot so that the slope is nearly vertical.
Like PEinc I normally set the vertical slope / wall back about 100mm (4 inch) and I have no problem running the analysis.
For modelling purposes the analysis will not change.
Thanks for ur advice...
I post that question because it's vertical tolerance give affect slope safety.
From the many trial and error method I think below 10cm can often derive a fatal error for analysis in some unlucky case.
So i wanted to know if there is any literature reference about that or papers which can back up that kind of error.
Thank u everybody~
