If it's possible, 1
WhyDoYouAsk
how do I calculate how much force is necessary to prevent metal from expanding because of a temp. rise?
You calculate the thermal expansion of the material and the force required to deflect it back in to place.
Garland E. Borowski, PE
Engineering Manager
Star Aviation
.......which is an application of Castigliano's second theorem – for displacements in a linearly elastic structure
Castigliano's method for calculating forces is an application of his first theorem, which states:
If the strain energy of an elastic structure can be expressed as a function of generalised displacement qi; then the partial derivative of the strain energy with respect to generalised displacement gives the generalised force Qi.
John
or you can use the easier familiar relationship to students of Strength of Material. Must assume a compact element.
S=E*e which can be in this other form
F/A=E*dl/L
S=compressive or tensile stress;E=modulus of eleasticity;e=strain;F=force; A=cross sectional area;dl= increase or decrease in length;L=original length before heating or cooling.
Hooke's law, I believe, since we are giving names to various formulae.
Thanks, folks. . .
This last one I must have learned at some point.
I guess I didn't apply it to other than textbook problems, and by the time I needed for the real world, I forgot I knew it.
Or some such thing. . .?
