Harry641,
We need a little more information on the rating of your motor.
1000 Volts supply is this the rating of the motor, or is it higher or lower?
250 Amps. Where is this with respect to the motor rating ?
If you have the motor commutator sparking and this test point is within the normal operating limits of the motor, then the fact that the ".....ARM,interpoles and brush boxes alignments are OK....." is not enough to eliminate the motor as being the cause of the sparking.
Sparking at the commutator is caused by brushes not being at the neutral point of the motor. The neutral point moves as a function of load and the purpose of the interpols is to counteract this effect to keep it at the point where the brushes are located. Other windings in the motor such as pole face windings also strive to keep the neutral position correctly located.
A failure in the interpol insulation (Shorted turns) will reduce the effectiveness of the interpoles and lead to sparking at higher load currents. Over voltage can also do this as mentioned by Waross.
A failed or failing "Equalizer" or even a failed main pole can cause sparking at almost any load level.
I am a litle puzzled by your comment that the motor is ".......being supplied by two series Dc generators...." This seems an odd configuration, but, just because I havn't heard of it doesn't make it wrong.
181273, we apply 2,000 HP DC motors, 8 mechanically in parallel that can go from full speed in one direction to full speed the other in about 3 seconds, giving a full cycle time if 6 seconds, This would be similar to a 10 Cycles per minute" AC waveform.
About the only time we put AC in the order of 50 or 60 Hz on the gernerator Fields is for locating the generator neutral point. It is a rough way of doing it but it gives limited success. The inductance of the fields is such that at 50 Hz, the impedence is so high that only very small 50 hz field current actually flows.
Tom Grayson
